Boggard11
Oct 25, 2020Aspirant
CBK752 Bufferbloat
Hi, Just wanted to know if anyone else was having crippling Bufferbloat with their CBK752 modem / router. Causing me huge latency and very unstable streaming (twitch), have tried everything I could b...
Oct 25, 2020Guru - Experienced User
Boggard11
Oct 27, 2020Aspirant
Using firmware V3.2.16.9, connection is wired so I'm not sure changing wifi related settings should have an impact, right?
- FURRYe38Oct 27, 2020Guru - Experienced User
Didn't know your having problems on wired connections.
How is your device connected? Does this device have a ethernet port?
Be sure your using good quality LAN cable. CAT6 is recommended.
Test streaming and video with a wired PC or laptop to compare results...
