Tonay
Dec 12, 2019Tutor
CBR 40 Dropping internet connection
Bought the CBR 40 with 1 satellite almost a month ago. Past week now it has been dropping connection like 5 times a day. Today it has dropped like 7 times in the past hour. Is it the modem route...
Dec 12, 2019Guru - Experienced User
thats a good question. We'd need more details to try to help you. We have to figure out first if its a modem side issue or a router side issue.
1. Is it both wired and wireless devices that are dropping? Or which types are dropping?
2. When the connection drops, are you still able to access the router/modem?
3. can you take a screen snip of your modem connections page and your modem logs? these help to figure out if the signal coming in is good/bad.
4. Is it dropping on all devices or only specific ones?
What have you done to try to fix the problem?
Does it resolve on its own or do you need to reboot it to fix the issue?
Who's your isp?
A couple things you can try. If there's any splitters, amplifiers, attenuators in the coax coming into the modem, remove these. Also check for loose connectors, corroded wired, kinked wire, or even just cheap connectors in the coax. these can cause issues and signal degradation.
Tonay
Dec 12, 2019Tutor
1. Is it both wired and wireless devices that are dropping? Both
2. When the connection drops, are you still able to access the router/modem? No
3. can you take a screen snip of your modem connections page and your modem logs? Where do I get this info?
4. Is it dropping on all devices or only specific ones? All
What have you done to try to fix the problem? Nothing
Does it resolve on its own or do you need to reboot it to fix the issue? Resolve on its own
Who's your isp? Comcast
- plemansDec 12, 2019Guru - Experienced User
Have you tried rebooting when it goes down?
What firmware is on the CBR40?
- TonayDec 12, 2019Tutor
Here is the logs: https://i.imgur.com/fMN8j9h.png and https://i.imgur.com/32eOuMh.png
Have you tried rebooting when it goes down? Once when the light on top was magenta
What firmware is on the CBR40? 2.3.5.12
you have quite a few errors in your line.
I'd try the prior suggestion about removing splitters/amplifiers/attenuators from the line.
I'd also move the modem/router right to where the coax enters the house. this removes the chance that its the wiring internal to the home causing the issues.
After you've done that. See how it runs, if its still having issues, have you isp check your line.
