dpb317
Jun 04, 2018Follower
CBR 40 modem with RBS50 sattelite
Can I add an RBS50 Satelite to a CBR 40 Modem/router? If not, is there a Orbi modem/router that will accomodate an RBS 50?
Jun 04, 2018Guru - Experienced User
I presume it possible. However the 40 system has lower connection rates while the 50 series has higher connection rates. Which the RBS50 is capable of.
I would post here with anything regard the new CBR40 systems:
https://community.netgear.com/t5/Orbi-with-Built-in-Cable-Modem/bd-p/en-home-orbi-cable
