masloco
Nov 28, 2020Aspirant
CBR 750 Ethernet Connection Issues
We just got the new Orbi CBR 750 Cable Modem Router. WiFi is spot on, strong, fast coverage... BUT... I like my desktop 2019 27" iMac running Catalina 10.15.7 (if that matters) to be wire...
- Nov 29, 2020
Problem solved? I went into to network preferences on the Mac and added the correct DNS address, hit apply, restarted, & BAM! Working! Odd that it would be that way to begin with, but fingers crossed.
masloco
Nov 29, 2020Aspirant
* A NEW WRINKLE HAS BEEN ADDED TO THE "SITUATION"....
I hadn't thought to try this previously, but I just connected another iMac to the the Orbi satellite via ethernet. Works like a champ.
I'm as far from expert on this as is possible and still possess oposable thumbs, but I noticed the DNS server listed under ethernet was different between the modem/router & the satellite. The modem router is xxx.xxx.0.1 and the satellite is xxx.xxx.1.1 (also the Wifi DNS server listed was xxx.xxx.1.x
- FURRYe38Nov 29, 2020Guru - Experienced User
You should remove any of the configurations from the Mac Networking area and let the Mac reconfigure the settings.
The DNS should be .0.1 coming from the CBR which is default for the CBR portion of the system. Have you set up the CBR from scratch with a wired PC and let it connect to the ISP service. I believe default IP address for the CBR is 192.168.0.1 which will be used as default DNS addresses connected client devices including the RBS.
- maslocoNov 29, 2020Aspirant
It didn't work with 192.168.0.1. It does work with 192.168.1.1. Go slow, give me the "For Dummies" version of why I should revert to the not working version. Will it cause some sort of other problem? The router address is 192.168.1.1
I didn't remove the .0.1 address, I just added the .1.1 address.
Thanks.
Ok, so the CBR is using .1.1. Then don't use .0.1, use .1.1.
