masloco's avatar
masloco
CBR 750 Ethernet Connection Issues
We just got the new Orbi CBR 750 Cable Modem Router. WiFi is spot on, strong, fast coverage...   BUT...   I like my desktop 2019 27" iMac running Catalina 10.15.7 (if that matters) to be wire...
  • masloco's avatar
    masloco
    Nov 29, 2020
    Problem solved? I went into to network preferences on the Mac and added the correct DNS address, hit apply, restarted, & BAM! Working! Odd that it would be that way to begin with, but fingers crossed.
