robhuff46's avatar
robhuff46
CBR40 - Blinking UPL blue light
My CBR40 started blinking blue light for UPL yesterday.  I shut everything down but can't get the light from blinking.  Had this cable/routerfor 6 month and this is first the light blinking.
  • FURRYe38's avatar
    I would have the ISP check there logs and signal to the modem. Give them any info from the CBR40's modem logs as well if needed.
