kw0712
Oct 07, 2019Aspirant
CBR40 - Does not pass traffic from an upstream Cisco L3 Switch
I have my CBR40 connected to a L3 switch with several upstream networks and the CBR40 will not pass the traffic to the Internet. I have static routes to all the upstream networks and I can ping ever...
Oct 07, 2019Guru - Experienced User
The CBK40 passes traffic from the internet thru its RG6 coax port. There is a built in modem already with in the CBK40 thus this is the interfacing service port to your cable ISP services and to the internet. All other Ports on the back of the CBR40 are LAN side ports. You can place a swich behind (downstream) the CBR40 on one of it's LAN ports, however, this should be a managed switch with IGMP protocols disabled or a non managed switch.
kw0712
I think you misunderstood upstream from downstream. Please see the attached diagram.
- FURRYe38Oct 07, 2019Guru - Experienced User
So do you get same results with a PC connected directly to the back of the CBR40?
Have you tried a different switch, something like a non manged switch with a PC behind the switch?
What is the model# of this Cisco switch?You might ask Cisco if there is a certain configuration needed on a Gateway or Router to effect correct traffic transportation with this switch. Possible there is a configuration needed maybe on the CBR40. This is a gateway router configuration.
- kw0712Oct 07, 2019Aspirant
It worked flawless with my xfinty modem/router. The Cisco switch is a 3750 and it is configured correctly. I have been buiding Cisco networks for 20 plus years.
It is something on the CBR40 ... I believe when a packet hits the CBR40 with a different subnet; then the local LAN subnet it does not know, what to do with the packet.
