kw0712
Oct 07, 2019Aspirant
CBR40 - Does not pass traffic from an upstream Cisco L3 Switch
I have my CBR40 connected to a L3 switch with several upstream networks and the CBR40 will not pass the traffic to the Internet. I have static routes to all the upstream networks and I can ping ever...
kw0712
I think you misunderstood upstream from downstream. Please see the attached diagram.
Oct 07, 2019Guru - Experienced User
So do you get same results with a PC connected directly to the back of the CBR40?
Have you tried a different switch, something like a non manged switch with a PC behind the switch?
What is the model# of this Cisco switch?
You might ask Cisco if there is a certain configuration needed on a Gateway or Router to effect correct traffic transportation with this switch. Possible there is a configuration needed maybe on the CBR40. This is a gateway router configuration.
- kw0712Oct 07, 2019Aspirant
It worked flawless with my xfinty modem/router. The Cisco switch is a 3750 and it is configured correctly. I have been buiding Cisco networks for 20 plus years.
It is something on the CBR40 ... I believe when a packet hits the CBR40 with a different subnet; then the local LAN subnet it does not know, what to do with the packet.
- FURRYe38Oct 07, 2019Guru - Experienced User
Does this happen with out the Cisco switch being on line?
Possible that there maybe a bug in FW or something that NG didn't intend for the CBR to support or not something most home users are widely using in there configurations.
- vkdeltaOct 10, 2019NETGEAR Employee Retired
Are the packets VLAN TAGGED when they hit CBR40?
have you configured reverse static routes on the CBR40?
