unreliableOrbi
Jan 12, 2019Aspirant
CBR40 - iPhone incorrect password and dropping Amazon Echo
I’m so frustrated with my Orbi system and even more frustrated with customer service who have been unprofessional, clueless and unreliable. I have a CBR40 and 2 satellites (RBW30 and RBS20). Almost...
kedarnath93
May 01, 2019Aspirant
Though it is a bit off topic, Yet it might help to fix few things..
The configured password is a much-needed thing for security concern. The devices remember the password once after the initial login and you don’t need to enter the password each time. Chances are high that you may not pay attention to remember the passwords other than your home network. Apple is keen about the security and at times, you may find difficult to find WiFi password on iPhone.
- michaelkenwardMay 01, 2019Guru - Experienced User
Isn't this down to user choice? It certainly is here on my Windows PCs. All browsers offer me the choice to remember passwords. I usually refuse on the grounds that I have password saving software.
