Glacialis
Dec 21, 2020Aspirant
CBR40 - Possible to exceed 866Mbps?
Upgrading from 200Mbps to gigabit internet, and I've never had an issue transferring data locally. Now though, I want to make sure I can get as much of that 940Mbps upload/download as I can. My CBR40...
Dec 21, 2020Guru - Experienced User
Correct, it's all that the CBK40 supports. Nothing more then that. These are connect rates between the Orbi wifi and wifi devices connected at 5Ghz AC only. Not actual data thruput. These are connection rates only.
- GlacialisDec 21, 2020AspirantThanks! If I really need that last 76 Mbps, I'll run a wired connection. :)
