mlock
Oct 16, 2018Guide
CBR40 - remove satellite?
How do you disconnect a satellite from the CBR40? RBS50Y outdoor satellite is not working on my system (maybe not even compatible ... different thread discussion). For now just want to remove it fr...
- Oct 17, 2018
Even after rebooting the router?
Oct 17, 2018Guru - Experienced User
Should be able to remove it from the routers UI, or just power OFF the RBSY.
mlock wrote:
How do you disconnect a satellite from the CBR40? RBS50Y outdoor satellite is not working on my system (maybe not even compatible ... different thread discussion). For now just want to remove it from the system as an attached device.
- mlockOct 17, 2018Guide
If it can be done from the User Interface - I haven't found it yet. Unplugged both of the RBS50Ys couple days ago, but they still show up as "Connected Satellites" under "Attached Devices".
