mlock
Oct 16, 2018Guide
CBR40 - remove satellite?
How do you disconnect a satellite from the CBR40? RBS50Y outdoor satellite is not working on my system (maybe not even compatible ... different thread discussion). For now just want to remove it fr...
- Oct 17, 2018
Even after rebooting the router?
mlock
Oct 17, 2018Guide
If it can be done from the User Interface - I haven't found it yet. Unplugged both of the RBS50Ys couple days ago, but they still show up as "Connected Satellites" under "Attached Devices".
Oct 17, 2018Guru - Experienced User
- mlockOct 18, 2018Guide
Yep - that did it. Was hesitant to hit reboot when all was working. Back to just the CBR40 & RBS20 that came with it. All good for now. Appreciate the help.
- FURRYe38Oct 18, 2018Guru - Experienced User
Glad that worked. The CBR works well as it is. I like mine.
Hopefully maybe NG can get the RBSY to work with it in the future.
Enjoy. :smileywink:
