HCC202
Oct 27, 2022Star
CBR40 - xfinity internet speed
I am using a CBR40 with Xfinity. I have 600 mbps and when I test my speed on the app I usually get around 190 - 210 mbps which doesn’t make sense to me. They recently upgraded my speed to 800mbps and ...
Oct 27, 2022Guru - Experienced User
Are you speed testing with a wired or wireless device? Wired is preferred.
HCC202
Oct 27, 2022Star
Router v2.5.0.28_1.0.8
- FURRYe38Oct 27, 2022Guru - Experienced User
Ok. Thank you.
Check wired speeds first. Those should be near to ISP spec if you have a good PC with a 1Gb ethernet adapter.
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?One User Experience/Configuration:
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026Do you have any Armor, Circle, parental controls or traffic meter enabled?
