Nufernandes's avatar
Nufernandes
CBR40 and RBS40V not getting along
I have the CBR40 in the living room, and the RBS40V in my office upstairs. Everything is perfect with coverage and speed except.... if I want to share files across my laptop wireless (win7) and my desktop (win10) wired they both have to be connected to the same orbi. If my laptop is upstairs it connects to the RBS40V and I can share files. If I bring the laptop downstairs, I can no longer share files because the laptop connects to the CBR40 instead. Is there a fix for this?
  • FURRYe38's avatar
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
    Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings.
    Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
    • Nufernandes's avatar
      Nufernandes
      The cable modem/router is on the first floor, and the RBS40V is upstairs. 4000 sq ft home. Wireless coverage is never an issue. The only problem is when I try to share files. If I take my laptop upstairs where the wired computer is connected to the RBS40V and go online, I can share files locally... if I come downstairs, and the laptop connects to the router instead of the RBS40V I can not share files.
      No neighbors for 3/4 of a mile... I'm on auto for the channel setting, but I'll try to play with the other settings you suggested.
      • FURRYe38's avatar
        Let us know. You may want to open a support ticket about this as well if the suggestions fail to resolve this.
