Pfredd
Apr 20, 2022Guide
CBR40 Can't access Internet through VPN
I have an Orbi CBR40 cable modem that I have configured VPN on. From my phone, I can connect to it using the OpenVPN Connect client. I can access local devices, but I can't access the internet. I h...
- Apr 20, 2022Yes, that is checked. I also tried Auto, but that didn't work either.
Maybe a firewall issue?
CrimpOn
Apr 20, 2022Guru - Experienced User
Repeated the experiment with the debug option "Enable LAN/WAN Packet Capture". That is:
- Turn off WiFi on phone.
- Use OpenVPN Connect app to VPN into the Orbi.
- Run the Fing app to ping some sites:
1.1.1.1 (CloudFlare) and 8.8.8.8 (GoogleDNS) - Observe that Ping is working correctly.
- Disconnect VPN
Opened the file wan.pcap with Wireshark. The capture file clearly shows the Orbi router sending ICMP packets to the two sites that I 'pinged' (1.1.1.1 and 8.8.8.8) and the sites responding.
So, for my Android phone, OpenVPN Connect appears to route internet traffic through the VPN tunnel, and the Orbi connects the VPN to the internet.
Am at a loss to explain why this is not working for you.
Pfredd
Apr 20, 2022Guide
Ok, I made some progress.
I disconnected my phone from wifi and connected it to the VPN. I then used Fing to ping 1.1.1.1. It worked!
It appears that this is a DNS issue, as trying to connect via domain names does not work. I will mess around with that for a bit to see if I can discover the issue.
- CrimpOnApr 20, 2022Guru - Experienced User
Hmmm. dns.google.com and ford.com both ping from my phone over VPN.
I distinctly remember (years ago) discussing OpenVPN with people who wanted to stream videos that were restricted to their home country when they were actually in another country. Not exactly kosher, but better than robbing liquor stores.
- PfreddApr 20, 2022Guide
I got it working!
I added the following to parameters to the OpenVPN Connect config file:redirect-gateway
dhcp-option DNS 8.8.8.8After re-adding the connection, it now works correctly!
redirect-gateway
Wow. You found it! My smartphone ovpn file does not contain this, but it works. My guess is there is something different about the OpenVPN Client on our phones. I do not see this as a setting (parameter) and do not see a way to control the level of detail in the OpenVPN log.Internet search for redirect-gateway returns quite a bit of information.
Every time someone posts an interesting problem on the forum, I learn something new!
