Pfredd
Apr 20, 2022Guide
CBR40 Can't access Internet through VPN
I have an Orbi CBR40 cable modem that I have configured VPN on. From my phone, I can connect to it using the OpenVPN Connect client. I can access local devices, but I can't access the internet. I h...
- Apr 20, 2022Yes, that is checked. I also tried Auto, but that didn't work either.
Maybe a firewall issue?
Pfredd
Apr 20, 2022Guide
I got it working!
I added the following to parameters to the OpenVPN Connect config file:
redirect-gateway
dhcp-option DNS 8.8.8.8
After re-adding the connection, it now works correctly!
CrimpOn
Apr 20, 2022Guru - Experienced User
redirect-gateway
Wow. You found it! My smartphone ovpn file does not contain this, but it works. My guess is there is something different about the OpenVPN Client on our phones. I do not see this as a setting (parameter) and do not see a way to control the level of detail in the OpenVPN log.
Internet search for redirect-gateway returns quite a bit of information.
Every time someone posts an interesting problem on the forum, I learn something new!
