rodstar1's avatar
rodstar1
CBR40 can't access router login unless modem restart. Updated firmware...
I know I am not the only one dealing with this. For months I can't access the Orbilogon, or Routerlogin of Orbi unless I restart it. Then a day or 2 later the same thing. I have updated the firmware, reset the unit and the problem keeps coming back, I am hoping my device is not failing???
1 Reply
  • FURRYe38's avatar
    What broswer are you using?
    Be sure to clear ALL browser caches before enter the routers web page.
    Can you access 192.168.1.1 or .0.1?
