johmarien1
Mar 25, 2020Aspirant
cbr40 connect to wireless printer Epson workforce 845
Mar 25, 2020Guru - Experienced User
the CBR doesn't connect to the epson. The epson connects to the CBR. Did you follow epsons manual, install guide, troubleshooting?
https://epson.com/Support/Printers/All-In-Ones/WorkForce-Series/Epson-WorkForce-845/s/SPT_C11CB92201
johmarien1
- johmarien1Mar 25, 2020Aspirant
To respond to reply that the workforce845 connects to the router. Yes I entered all correct info into printer per epson web site 5 or six times w/ same result. Ran network check security key / password check failed they are correct ip adress unchecked / detailed ip setup check unchecked. The printer generates a pin code which it says to enter into the computer within two minutes. were would you enter that pincode. also ran Microsoft check and all is correct. printer is default . I'm not a techy. could it be ip address ?
- plemansMar 26, 2020Guru - Experienced User
If its just the epson not connecting, I'd contact epson for help setting it up. they'll be the experts on the best way to connect their product to a home network.
