rbenso1
May 23, 2019Aspirant
CBR40 device and internet issues
I'm having multiple issues with my new CBR40. Installed it and set it up with Spectrum as my ISP, per the Netgear instructions. For wireless phones, e.g. iPhone 7plus, the wifi seems to connect ju...
rbenso1
May 24, 2019Aspirant
Thanks for the assistance. Firmware is V2.3.0.10.
Updated it when I first installed it to what it said was the latest rev. My neighbor has the only other wireless network nearby. The satellites both seem to be working fine. One is about 15ft away but upstairs and one is about 35ft away .
Cable company says there’s been no issues on the line.
Tried configuring per your instructions but unfortunately the PCs and TV still don’t see the internet. They connect to the WiFi just fine. Same issue happened with the phone. Just sporadically saying no internet. The Directv box at least recognized the hard Ethernet line, so that was progress.
May 24, 2019Guru - Experienced User
Try a factory reset on the CBR40. Then setup from scratch. Turn OFF all RBS and just test with the wifi at the CBR unit.
The one RBS at 15 feet is tooo close. 30 feet distance minimum.
Is Daisy Chain enabled Under Advanced Tab/Advanced Settings/Wireless Settings?
