jjh636
Oct 19, 2021Tutor
CBR40 orbi login page
Hello, I am having problems with the Orbi page. I can login fine and everything seems okay, however when i click on the Cable connections or wireless tab, it times out with the error "connection w...
Oct 22, 2021Guru - Experienced User
Any progress on this?
jjh636 wrote:
Hello,
I am having problems with the Orbi page. I can login fine and everything seems okay, however when i click on the Cable connections or wireless tab, it times out with the error "connection was reset" or "192.168.1.1 did not send any data". Any reason why this is happening? My firmware is up to date.
- jjh636Oct 22, 2021Tutor
No, I am sitll unable to get into cable connections or wireless tab once i login even though it initially says connection status: good. I have tried it in edge, chrome, firefox. Wired/wireless. I dont know when it started, the last time I was able to see that page was maybe ~ 1 month ago? I just started checking because I am getting severe signal loss on my satellite, but that is another probelm i will ask whenever I ahve the time.
- FURRYe38Oct 22, 2021Guru - Experienced User
I recommend trying this, downgrade both CBR and RBS to
CBR40 Firmware Version 2.1.3.14
RBS20 Firmware Version 2.1.3.4https://www.netgear.com/support/product/CBK40.aspx#download
I would use MS Edge or FIreFox browser to downgrade the RBS first then CBR lastly.
After FW is applied and the RBS and CBR are online. Power both OFF for 1 minute or more, then back ON.
