jjh636
Oct 19, 2021Tutor
CBR40 orbi login page
Hello, I am having problems with the Orbi page. I can login fine and everything seems okay, however when i click on the Cable connections or wireless tab, it times out with the error "connection w...
jjh636
Oct 22, 2021Tutor
No, I am sitll unable to get into cable connections or wireless tab once i login even though it initially says connection status: good. I have tried it in edge, chrome, firefox. Wired/wireless. I dont know when it started, the last time I was able to see that page was maybe ~ 1 month ago? I just started checking because I am getting severe signal loss on my satellite, but that is another probelm i will ask whenever I ahve the time.
Oct 22, 2021Guru - Experienced User
I recommend trying this, downgrade both CBR and RBS to
CBR40 Firmware Version 2.1.3.14
RBS20 Firmware Version 2.1.3.4
https://www.netgear.com/support/product/CBK40.aspx#download
I would use MS Edge or FIreFox browser to downgrade the RBS first then CBR lastly.
After FW is applied and the RBS and CBR are online. Power both OFF for 1 minute or more, then back ON.
