billmoise
Jun 26, 2020Follower
CBR40 random loss of connectivity
ORBI CBR40 running the latest firmware on COX 150M/10M. My issue to say the least is weird. I went back to my old Zoom modem because I'm experiencing loss of connectivity to my work environment. ...
Jun 26, 2020Guru - Experienced User
Press the back reset button for 15 seconds then release.
