FLMoose
Sep 26, 2022Aspirant
CBR40 randomly disconnects after firmware update
Hi. I have a CBR40 router with two RBS20 satellites that I installed two years ago and have been working flawlessly. On Friday, I logged into the Orbi app and installed the "new" v2.5.0.28 firmware....
FLMoose
Oct 06, 2022Aspirant
Before my original posting, I had rebooted modem/router combination as well as unplugged it. I had my ISP check the signal and everything reports good.
After posting, I pulled the error log (attached) and noticed the MIMO warning. Not sure how to correct this.
On Monday, I was finally able to power down my entire Wifi completely. The modem/router, satellites, and all connected units were unplugged for 10 hours while I was at work. I powered on and rebooted the modem/router first. After about 5 minutes, I checked and all lights were illuminated. I then began powering up my network once item at a time. For the first 3 or 4 hours everything seemed great (I was streaming videos with now connection issues), but then the system began going offline periodically again. About 3 to 4 times that night. I rechecked the log and no new errors had occurred.
Oct 06, 2022Guru - Experienced User
Please post a copy and paste of the modems connection status page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
The events log page shows lots of Criticals that the ISP needs to review and help resolve.
How many RBS do you have deployed?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
