Malex10
Aug 02, 2020Follower
CBR40, RBS40 (W/ ethernet backhual), and RBS40V not working
I recently purchased a RBS40v to extend my network over wireless backhual, after setting it up my entire network has become unstable and my ethernet connected RBS20 has stopped working. The network h...
Aug 12, 2020Guru - Experienced User
Something to try to update the RBR40v FW:
What you need to do is factory reset the RBS. Wire connect a PC to the 1st satellite. Already have the most current FW version files downloaded on to this PC.
Wire connect 1 PC to the back of the RBS. Factory reset the RBS, wait about 5 minutes. The PC will get a IP address from the satellite. The RBS will be 192.168.1.250. Use this IP address in a web browser to log in to the satellites web page. Log in as admin and password. Use the satellites web page FW update feature to select the FW update file that was unpacked from the .zip file. Then factory reset and then re-sync the satellites to the RBR.
