LoriKB
Jun 11, 2020Follower
CBR40 reset did not work after trying hard reset?
Sort By
Maybe some more details would help.
whats going on?
Why are you resetting it?
Whatt issue are you having?
What are the led's doing?
We need more than "reset did not work".
Pressing the back reset button for 15 seconds then release should reset the CBR40. Then use a wired PC connected to the CBR and a web browser pointed at 192.168.0.1 should bring up the setup wizard.
