Troy46
Aug 08, 2020Aspirant
CBR40 to wired connection
I have 3 building with one internet service. The internet runs to a CBR 40 in the main building, the next building has a RBW30 extender that does an OK job of picking up the WiFi from the CBR40 the 3...
Mstrbig
Aug 09, 2020Master
Troy46 wrote:I have 3 building with one internet service. The internet runs to a CBR 40 in the main building, the next building has a RBW30 extender that does an OK job of picking up the WiFi from the CBR40 the 3rd building is wired from the CBR40 and all the devices in that building are hardwired from a splitter. I want to get wifi in the building that is wired and there are enough connections on the splitter but want it to be the same wifi network as the other buildings so when you go back and forth you do not have to switch wifi's. Any suggestions on how to do this?
Assuming the splitter you are mentioning is a switch, your best bet for maximum coverage is to configure an Orbi satellite and connect it to the switch. The model you purchase depends on how much coverage you want, as different models have differenge range
