crowe1288greg
Jun 20, 2020Aspirant
CBR40 wired speed slower than wifi speed
I have a CBR40 with reasonable high speed internet. My ipad shows 230 - 240Mb. My Dell desktop wired has a speed of 80 - 90 MB. Dell control panel shows Dell GigabitEthernet adapter. I've confirmed ...
Jun 20, 2020Guru - Experienced User
Have you tried changing the cable?
Have you tested it with a different device to see if its an issue with the router or with the dell?
- crowe1288gregJun 20, 2020Aspirant
Yes, I've changed the cable. No difference. I'll have to get a different computer.
- plemansJun 20, 2020Guru - Experienced User
You can borrow one potentially. Its just to test to see if it is indeed the adapter or if its the router.
does it do the same thing if its plugged into the router or the satellite?
Any switches in line?
