jjh636
Jun 30, 2020Tutor
CBR40 with 2 RBS20 connection loss and slow speeds
Hello, This has been an ongoing issue - bought this modem/router in feb and since then it has lost connectivity ~ 4-5 hours at a time at least once or twice a month. Everytime this happens, I chec...
- Jul 01, 2020
Your line is a bit low on power. the notices from the event log point to a signal issue.
If you have any splitters, attenuators, amplifiers in line, remove them.
Your isp might need to check the line.
Jul 01, 2020Guru - Experienced User
When its dropping, is it just wireless or is it both wired and wireless devices?
Do you have a screen snip of the cable connections page? And the logs? this helps check the signal back to xfinity.
