jjh636
Jun 30, 2020Tutor
CBR40 with 2 RBS20 connection loss and slow speeds
Hello, This has been an ongoing issue - bought this modem/router in feb and since then it has lost connectivity ~ 4-5 hours at a time at least once or twice a month. Everytime this happens, I chec...
- Jul 01, 2020
Your line is a bit low on power. the notices from the event log point to a signal issue.
If you have any splitters, attenuators, amplifiers in line, remove them.
Your isp might need to check the line.
jjh636
Jul 01, 2020Tutor
Jun 30 2020 11:42:05Warning (5)Lost MDD Timeout
Jun 30 2020 11:42:44Critical (3)Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out
Jun 30 2020 11:42:53Critical (3)SYNC Timing Synchronization failure - Loss of Sync
Jun 30 2020 11:44:26Critical (3)Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out
Jun 30 2020 11:44:41Critical (3)No Ranging Response received - T3 time-out
Jun 30 2020 11:44:54Warning (5)MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
Jun 30 2020 11:44:56Critical (3)No Ranging Response received - T3 time-out
Jun 30 2020 11:58:19Critical (3)SYNC Timing Synchronization failure - Loss of Sync
Jun 30 2020 11:58:25Warning (5)Lost MDD Timeout
Jun 30 2020 12:31:39Critical (3)No Ranging Response received - T3 time-out
Jun 30 2020 14:45:14Warning (5)MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
Jun 30 2020 17:06:33Critical (3)No Ranging Response received - T3 time-out
Jul 01 2020 07:26:05Critical (3)SYNC Timing Synchronization failure - Loss of Sync
Jul 01 2020 07:56:34Warning (5)Lost MDD Timeout
Jul 01 2020 07:57:16Critical (3)Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out
Jul 01 2020 08:00:48Critical (3)No Maintenance Broadcasts for Ranging opportunities received - T2 time-out
Jul 01 2020 08:03:39Warning (5)MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
Jul 01, 2020Guru - Experienced User
