jjh636's avatar
jjh636
Tutor
Jun 30, 2020
CBR40 with 2 RBS20 connection loss and slow speeds
Hello,  This has been an ongoing issue - bought this modem/router in feb and since then it has lost connectivity ~ 4-5 hours at a time at least once or twice a month.  Everytime this happens, I chec...
  • plemans's avatar
    Jul 01, 2020
    Your line is a bit low on power. the notices from the event log point to a signal issue.
    If you have any splitters, attenuators, amplifiers in line, remove them.
    Your isp might need to check the line.
