Mandisara's avatar
Mandisara
Follower
Jun 22, 2020
CCTV and Orbi
Hi everyone, can I plug a cctv camera hub into my Orbi or does it have to plug into our Netgear router?
  • Do you mean can you plug the hub into the satellite or the primary router?
    You should be able to plug it into either.
  • Contact the mfr of the CCTV camera to see what the camera can or needs to be connected too.
  • As plemans remarked, the question appears ambiguous:
    • Netgear manufactures "Orbi" among other things.
    • Is the "Netgear router" the Orbi, or is the Orbi connected to an existing Netgear router?
    • Is the point to access CCTV from within the local network, or remotely?
