PhilHelp
Aug 13, 2020Initiate
Cell Phone Signal
I just purchased and installed an Orbi RBK50 with one satlite. Can I use it as a signal booster for my iPhone? My wood shop is a steel building and I cannot get a signal for my phone while in it. TIA...
Mstrbig
Aug 13, 2020Master
If you are talking about 4G there is no support for that. If you are talking about WIFI it depends on placement and distance. How far is the shed from the orbi.
