Retired_Member's avatar
Retired_Member
Sep 28, 2019
cell phone will not connect to satellite
My various cell phones will not connect to satellites.  If I stand by the Router then they will link up and stay that way (until I leave my house).  Everything has worked okay until about a month ago (when I ran out of mobile data).  I have reset everything to factory settings (including 1 phone).
Besides the original 2 piece setup, I have 2 RBS20s.
This may have something to do with it, about the same time, I lose connection to my Google home mini.  I can relink the satellites and this comes back.  This happens every night (& sometimes during the day).
2 questions:
1) can you help with these problems?
2) can you tell me why I should sick with Orbi because after about a year of different problems, I am about to give up?
1 Reply
  • FURRYe38's avatar
    Is the Orbi system operating in Router or AP mode?
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
    Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
    2 questions:
