xyu
Oct 19, 2018Aspirant
Cellphone cannot connect to smartplug in ORBI(RBK22) network
After switching to this ORBI system (RBK22), my celphone was connected with 5GHz, but my smart plugs use 2.4GHz, and the cellphone cannot communicate to the smart plug anymore. The error message says...
Oct 19, 2018Guru - Experienced User
What FW is currently loaded?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-and-connection-problems-Skybell/m-p/1649275/highlight/true#M43001
xyu
Thanks for the reply. However, it did not work for me. What I did is to connect an old netgear router with 2.4g and 5g channels and only broardcast the 2.4g channel. The cell connected to the 2.4g netgear network and is able to talk to the smartplug and setup the plug. After setup, the cellphone can switch to the ORBI network and still keep connection to the plug.
- FURRYe38Oct 19, 2018Guru - Experienced User
sounds like your cell phone isn't working right with the Orbi system if you have to do that process. Something to ask the cellphone Mfr about and or the smartplug and see. Some MESH systems maybe incompatible with some phones or smart plug devices.
Sounds like you got it working though.
Enjoy.
