xyu
Oct 19, 2018Aspirant
Cellphone cannot connect to smartplug in ORBI(RBK22) network
After switching to this ORBI system (RBK22), my celphone was connected with 5GHz, but my smart plugs use 2.4GHz, and the cellphone cannot communicate to the smart plug anymore. The error message says...
LadyoftheLake
Oct 30, 2018Aspirant
I had the same problem connecting to a tplink smart plug. I followed your advice and changed the 2.4GHZ channel to 1 and disabling the iPv6. At first it didn't work. Then I tried adding a device to the SmartLife app and it picked up the wifi and added the smart plug. Thanks for the tip.
Oct 30, 2018Guru - Experienced User
Thanks for letting us know. Glad it worked.
Enjoy. :smileywink:
