Tewkstus
Dec 12, 2017Initiate
Centrylink fiber
I recently had Centrylink fiber installed (Arizona) and, if possible, would like to remove the Centrylink provided model/router and go directly from the ONT to my Orbi router. I understand Orbi s...
DarrenM
Dec 14, 2017Sr. NETGEAR Moderator
You will want to check out page 44
http://www.downloads.netgear.com/files/GDC/RBK50/Orbi_UM_EN.pdf
DarrenM
- TewkstusDec 14, 2017Initiate
Thanks Darren, appreciate it. After trial and error, I believe the Orbi router doesn’t currently support this configuration. PPPoE username and password looks ok but I think the issue is the Orbi doesn’t allow a change/edit of the “Internet in port” VLAN tagging ID change from 10 to 201.
I’ll next try a managed switch to see if the VLAN ID issue can be satisfied.
