Rschachel
Apr 08, 2020Aspirant
Century Link DSL Modem/Router C1100T with Orbi RBR20
I just had to order a new modem/wireless router C1100T from CenturyLink after having problems with my old wireless router. It is connected to Orbi RBR20. I have been experiencing security issues w...
- Apr 08, 2020
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Apr 08, 2020Guru - Experienced User
Modem Combo Units:
Couple of options,
- RschachelApr 08, 2020Aspirant
Thank You, Solution 3 worked best for me. Now I can't see any of my connected devices on the App but I can leave that as an issue for another Day, Haha. Just happy I can connect.
- FURRYe38Apr 08, 2020Guru - Experienced User
Post back about that later on.
If your using the Orbi app, please post over in the Orbi app forum:Please post about this in the Orbi app forum:
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-appEnjoy. :smileywink:
