creed0330
Oct 29, 2020Tutor
Centurylink Fiber and RBK50
Hello all, let me start by stating that I have read tons of forums on this and am still stuck. I have CL Fiber with the C4000XG modem from CL, and just recently bought the RBK50 pack. Breakdown ...
Oct 29, 2020Guru - Experienced User
Are speed testing with a wired PC or wireless device?
You'll need to ask your ISP about the IPoE protocol if that something that can be used on external routers...
Seems like the modem maybe trottling the Orbi data flow...
jhoff909
Oct 30, 2020Apprentice
Do Furry's #3. I tried all the others and got things to work but the only way I could get full fiber speed was with the orbi in AP mode. I really really wanted to take the CL modem out of the picture all together. I did get it working that way but the orbi couldn't keep up when it was doing both wifi, nat and routing. Speeds were, I forget exactly but I think in the 500mbps range instead of the 925 or so that you should get with gigabit fiber.
