creed0330
Oct 28, 2020Tutor
Centurylink Fiber and RBK50
Hello all, let me start by stating that I have read tons of forums on this and am still stuck. I have CL Fiber with the C4000XG modem from CL, and just recently bought the RBK50 pack. Breakdown ...
creed0330
Oct 30, 2020Tutor
Yea, I dont expext gig speeds via wifi, but I would like to know how to configure my orbi for IPOE.
jhoff909
Oct 30, 2020Apprentice
creed0330 wrote:Yea, I dont expext gig speeds via wifi, but I would like to know how to configure my orbi for IPOE.
Do some searches. I have CL gigabit fiber but it uses PPPOE instead. As best I can tell, with IPOE, yours should either just work or you have to set vlan tagging up using 201 as the tag. Have a look at: https://www.reddit.com/r/orbi/comments/gxtg6h/bypassing_cl_fiber_modem_something_seems_off/ although I don't think it fully discusses your issue. I found that when I tried to take the CL router out of the system, that the orbi wasn't able to keep up doing routing, wifi and NAT. Even wired, I couldn't get close to gigabit speeds. The newer Orbi's might but I don't really know. You can do some more searching but I found a lot of posts that suggested that the orbi just isn't a great, fully featured router and that the CL eq is better at that - just the wifi perf isn't great. So let the CL box do the routing and the orbi do the wifi in AP mode. I'm curious what your wired speeds look like once you do get it working tho... if...
