Geary
Dec 30, 2021Aspirant
Challenges adding wired backhaul satellite in AP mode
I have a fairly basic network config that's giving me some trouble. Issue: RBR50 can't find the RBS50 to add it as a satellite. Attempts to add it fail both from the mobile app as well as ...
CrimpOn
Dec 30, 2021Guru - Experienced User
Geary wrote:
Basic config:RBR50 connected via a LAN port to a switch, into which both my incoming WAN link and an RBS50 are plugged. RBR50 configured in AP mode.
This is the issue. Connecting both the WAN port and a LAN port to the same switch as the link to the modem will fail. The Orbi only recognizes satellites when they appear on the LAN port. Connect the modem directly to the Orbi WAN port, not to the switch.
