Hrannarm
Feb 11, 2020Initiate
Change connection on Iphone to 2.4GHz in Orby app
Hi. I am trying to connect my security cameras to my iPhone and it says I need to have my phone on 2.4GHz, how can i switch to 2.4GHz in my mobile orby app??
Hrannarm
Feb 12, 2020Initiate
They have there own app, denali I think it is and they say that I can only add the camera on 2.4Ghz
Feb 12, 2020Guru - Experienced User
Once you disable the 5Ghz SSID broadcast, save and apply. Do a "Forget this Network" on your phone or pad. Disable the wifi radio on the phone or pad, then re-enable it, then reconnect to the Orbi WiFi. The phone or pad should be now connected to the 2.4Ghz frequency.
