pondorondo
Mar 25, 2020Aspirant
Change Connection Type from 5G to Wired (RBK23)
Hi there, when I set up my router and satellites all the devices were connected to the same switch. As it turns out, - one of the satellites is now indicated to be connected with connection type 5G...
- Mar 25, 2020
Ok. So that configuration should work well.
pondorondo
I have a TP-Link SK5428 switch. It is run without any management features. The router and the satellites are connected as it is indicated in the third picture with the switch - except that I use the yellow socket for plugging in the LAN cable.
The Orbi router is run in AP mode since it is connected to a firewall router.
"30 feet is recommended": When I setup my connections the router and the satellites were indeed much closer. Do you thins I have to do a factory reset and begin with the setup from the beginning in order to change the connection type? :-(
Mar 25, 2020Guru - Experienced User
Please confirm the model# of the swtich. I don't see a SK series switch listed for TPLink...SG or SL maybe?
I would connect each RBS directly to the back of the RBR to ensure they work and appear as a wired RBS first. Then place back in there remote locations. Usually wireless synce first, then once you see top ring BLUE, connect the ethernet cable and give 5 minutes for it to complete the migration to ethernet. Check the status.
- pondorondoMar 25, 2020Aspirant
Sorry, it was a typo. The correct model is a TP-Link TL SG5428
https://www.tp-link.com/de/business-networking/managed-switch/tl-sg5428/
Thanks for your advice. Am I correct that your proposal requires a factory reset?
"migration to ethernet" means "migration to wired connection" or changing the connection to use the switch?
- FURRYe38Mar 25, 2020Guru - Experienced User
Ok, that switch is a managed switch. Please ensure all IGMP protocols on this switch are disabled. This has been known to cause problems between RBR and RBS when ethernet connected to switches. Try this first.
IGMP is already disabled ..... :-(
