pondorondo
Mar 25, 2020Aspirant
Change Connection Type from 5G to Wired (RBK23)
Hi there, when I set up my router and satellites all the devices were connected to the same switch. As it turns out, - one of the satellites is now indicated to be connected with connection type 5G...
- Mar 25, 2020
Ok. So that configuration should work well.
pondorondo
RBR is running in AP mode
Mar 25, 2020Guru - Experienced User
- pondorondoMar 25, 2020Aspirant
Thanks a lot for your help. The last setup discussed above indeed works:
- both satellites are indicated as being connected "wired" to the router
- the satellites are directly connected, not daisy chained
The only problem is, that the new setup is more complex, I need an additional switch and loose a wall socket for another LAN cable. But that is a different problem.
Thanks again!
- FURRYe38Mar 25, 2020Guru - Experienced User
Glad it works. Enjoy. :smileywink:
