Shahab
Mar 24, 2020Apprentice
Change DNS Settings on Orbi
Hi, How do you change the DNS Servers on the Netgear Router administration page? I have an Orbi RBR40 router with 2 RBR30 Satellites and have been experiencing intermittent internet connectivity is...
Mar 25, 2020Guru - Experienced User
What browser are you using?
Try a factory reset on the RBR while it's disconnected from the ISP modem. Manually setup the RBR with a wired PC and try IE11 or FireFox and go in and try to change the DNS values. They should be editiable...
Shahab
Mar 25, 2020Apprentice
I have been using Firefox. Netgear is replacing the router as well, supposed to arrive today, so will be setting up a new device. Will see if that helps. It's almost as if there is some scheduled task running that causes the disruption mid-morning, but don't know what it would be especially since I have disabled Circle.
Shahab
