Shahab
Mar 24, 2020Apprentice
Change DNS Settings on Orbi
Hi, How do you change the DNS Servers on the Netgear Router administration page? I have an Orbi RBR40 router with 2 RBR30 Satellites and have been experiencing intermittent internet connectivity is...
SW_
Mar 25, 2020Prodigy
Shahab wrote:...Has anyone else experienced this issue?
Yes. A possible workaround that might work for you.
Shahab
Mar 25, 2020Apprentice
thank you for the link to the post, that's pretty much the same issue I'm having, didn't go into the in depth troubleshooting like the other users. Will try it out if I run into issues with the replacement router.
- FURRYe38Mar 25, 2020Guru - Experienced User
Also as another test, connect a wired PC directly to the ISP modem. Do you get internet access here.
Shahab wrote:thank you for the link to the post, that's pretty much the same issue I'm having, didn't go into the in depth troubleshooting like the other users. Will try it out if I run into issues with the replacement router.
- ShahabMar 25, 2020Apprentice
So I just got the replacement router they sent me. The replacement router is an Orbi Mini Router RBR40, my original one was an Orbi Router RBR40. Is there a difference between these two? I wasn't able to find anything searching online. Also why doesn't RBR40 show up in the Model search above? If you type in RBR, you get RBR20 and 50
- CrimpOnMar 25, 2020Guru - Experienced UserThe forum drop down menu is (synonym for embarrassing, disgrace, inadequate). Click on the Support link at the top of the page for a REAL list of products.
