Shahab
Mar 24, 2020Apprentice
Change DNS Settings on Orbi
Hi, How do you change the DNS Servers on the Netgear Router administration page? I have an Orbi RBR40 router with 2 RBR30 Satellites and have been experiencing intermittent internet connectivity is...
Shahab
Mar 25, 2020Apprentice
So I just got the replacement router they sent me. The replacement router is an Orbi Mini Router RBR40, my original one was an Orbi Router RBR40. Is there a difference between these two? I wasn't able to find anything searching online. Also why doesn't RBR40 show up in the Model search above? If you type in RBR, you get RBR20 and 50
Mar 26, 2020Guru - Experienced User
Is the new replacement system working?
Shahab wrote:So I just got the replacement router they sent me. The replacement router is an Orbi Mini Router RBR40, my original one was an Orbi Router RBR40. Is there a difference between these two? I wasn't able to find anything searching online. Also why doesn't RBR40 show up in the Model search above? If you type in RBR, you get RBR20 and 50
- ShahabMar 26, 2020Apprentice
Router is working so far, I haven't been able to get the Satellites to connect to it yet, despite several attempts. I'll be monitoring through the day to see if the connection stays up.
- ShahabApr 01, 2020Apprentice
So I'm starting to have the same issues again with the new router. I made sure not to enable Circle when I got the new router, so not sure why it's acting up again. Will open a new support case with Netgear.
Shahab
- FURRYe38Apr 01, 2020Guru - Experienced User
Try a full power OFF of the ISP modem and RBR for 1 minute then back on if you see anything happen again.
It it still happens try downgrading FW to v30 to see if this corrects the problem.
Make contact with NG support as well.
Last thing you can try is voxels FW:
Shahab wrote:So I'm starting to have the same issues again with the new router. I made sure not to enable Circle when I got the new router, so not sure why it's acting up again. Will open a new support case with Netgear.
Shahab
