mclink's avatar
mclink
Follower
May 18, 2019
Change from ATT to Orbi
I will be changing cable servive ftom ATT Uverse to Comcast Triple Play.....TV / Internet / Phone and need to replace to ATT supplied router. CAN I REPLACE IT WITH ORBI RBK50 SYSTEM (1 ROUTER + 1 SATELLITE) ? AND WILL THE ORBI ROUTER ALLOW LAND LINE PHONE CONNECTION ?
  • CrimpOn's avatar
    CrimpOn
    Orbi RBK50 does not support a POTS (Plain Old Telephone Service) line, what we used to call a "2500 set" in Western Electric terminology.  When Comcast provides telephone service, they will supply a modem which provides a telephone jack that you can connect to whatever you want.  I have mine (Spectrum) connected to the base unit of a Panasonic cordless system with six handsets.  Some people connect to the existing telephone wiring in the house.
    What you want to do is ask Comcast to install a modem/phone only unit, with no router and no WiFi.
    That way, the Orbi will provide router functions and WiFi.
    There is a model of Orbi that bundles a data modem into the unit, but it does not provide telephone service.
  • FURRYe38's avatar
    You can get a Orbi with a built in cable modem if thats of any interest:
    https://community.netgear.com/t5/Orbi-with-Built-in-Cable-Modem/We-Squeezed-a-Cable-Modem-under-the-hood-of-the-new-Cable-Modem/td-p/1566119
