CrimpOn
Nov 01, 2018Guru - Experienced User
Change in Sending Log Files
Just noticed another change in the way Orbi handles log files. In the past, when a log filled, the Orbi would email it out, clear the log file, and start over. Now, the Orbi sends the log file ever...
CrimpOn
Thanks for the tip. I looked at Advanced->Security->EMail, and this is what it shows:
i.e. That's what I set it to months ago, and it's still set that way. Only the behavior has changed. My firmware is V2.2.1.210
I will set it to something else, and then set it back. Will be interesting to see tomorrow morning if I get an email (or not).
Christian_R
Nov 01, 2018NETGEAR Employee Retired
CrimpOn - Thank you for getting back. Please let us know the outcome and if you require further assistance. I can see if we can get support to contact you.
~Christian
- CrimpOnNov 02, 2018Guru - Experienced User
Same behavior. Got log file this morning just after midnight. Sending when "not full" does not clear the log, so most of what I got duplicates the file I got yesterday.
My next step it to restart the router and see if that somehow "clears something."
- larryindublinNov 02, 2018Luminary
I have seen the same thing. Haven't tried doing a full reset yet though. Also on the latest official firmware.
