CrimpOn
Nov 01, 2018Guru - Experienced User
Change in Sending Log Files
Just noticed another change in the way Orbi handles log files. In the past, when a log filled, the Orbi would email it out, clear the log file, and start over. Now, the Orbi sends the log file ever...
Nov 02, 2018Guru - Experienced User
CrimpOn
Just thought I'd mention....... I understand completely that "reset to factory and configure from scratch" is the solution of (next to last) resort. Some bit in there is corrupted and tinkering with settings simply never clears it. However, that's a lot like the advice to "wipe your hard drive, reinstall Windows from CD, reinstall all your apps, reconfigure everything....." and see if that helped. i.e. resetting to factory involves a considerable effort. (inputting IP reservations, setting device names, setting up log email, etc. etc. etc.) If my Orbi "didn't work", I would be all over this. Mine works. It updates firmware automatically. Performance is great. I just think the log file handling is messed up. I checked ALL the boxes, but the log shows only DHCP assignments. I asked to send the log "when full", but it sends every day.
p.s. "Last resort" seems to be to manually downgrade to earlier firmware and jump through hoops to keep the Orbi from updating itself. No chance of that by me!
- CrimpOnNov 05, 2018Guru - Experienced User
Well, gone completely wack-o now. This morning I thought, "hey, did I miss getting my daily log file?" In Advanced->Admin->Logs, this is what I see:
[admin login] from source 192.168.1.2, Monday, November 05, 2018 10:23:37
[Time synchronized with NTP server] Saturday, November 03, 2018 10:35:58
[admin login] from source 192.168.1.2, Friday, November 02, 2018 18:47:58
[admin login failure] from source 192.168.1.2, Friday, November 02, 2018 10:37:21
[Time synchronized with NTP server] Friday, November 02, 2018 10:35:56
[admin login] from source 192.168.1.2, Friday, November 02, 2018 10:34:54
[Initialized, firmware version: V2.2.1.210] Friday, November 02, 2018 10:34:38i.e. Between Friday and Monday, the ONLY thing logged was NTP sync and admin logins. NO DHCP leases. Nothing! I guess it's a good thing that it no longer sends a log every midnight, but this is just weird. All the possible boxes remain checked:
- ekhalilNov 05, 2018Master
This happened also to me, all my DHCP messages suddenly disappeared from the Logs and I could only see -as you mentioned- the NTP syncs, admin logins and also DoS attempts. Then I did a factory rest and started to see DHCP messages, NTP syncs, admin logins, but the DoS attempts disappeared :)
This -for sure- is a bug in the SW that I really hope that NG will have a look at and fix soon.
- CrimpOnNov 11, 2018Guru - Experienced User
Well, Orbi logs certainly are interesting. I rebooted the Orbi on Nov 8 and it's back to more "normal" behavior. Only sends a log when full. Log includes DHCP assignments and Network Time. Intrusion, etc. still missing. I guess the oldest advice is still valid, "when in doubt, reboot."
By-the-way, I can understand why it is probably pointless to log intrusion attempts. (1) there easily can be hundreds every day, causing the log to fill and be sent more often than people would enjoy. (2) Since the attempts have been logged, one assumes that they have also been repelled. So, "why would anyone care?" I simply think (a) they were there before, why change? and (b) why not give users the option to see or not see?
