CrimpOn
Nov 01, 2018Guru - Experienced User
Change in Sending Log Files
Just noticed another change in the way Orbi handles log files. In the past, when a log filled, the Orbi would email it out, clear the log file, and start over. Now, the Orbi sends the log file ever...
Retired_Member
Nov 23, 2018Having the same identical issues with logging since upgrade to v2.2.1.210 from v2.1.4.16. Factory Reset made no difference.
